Hello. Until now, I had no problem to delimit the Twizy's from 2012 to 2015 with the OVMS V2 module, but today I wanted to delimit a 45 model from the year 2012 and it was impossible... these are the SMS that I received when sending CFG POWER 120 and CFG SPEED 75: CFG POWER: ERROR 0008 SDO ABORT 0x6076.00: 0x08000000 CFG SPEED: LOGIN FAILED ERROR 0043 The sim card and the telephone number is the one that I have always used and is registered in the module and with sufficient balance, but there is no way to delimit it... what could be the problem? It's been more than two years since I used OVMS V2. Thank you very much and best regards
You can find the Twizy documentation here:
https://docs.openvehicles.com/en/latest/components/vehicle_renaulttwizy/docs/index.html
and the most complete V2 manual here:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System/raw/master/docs/Renault-Twizy/OVMS-UserGuide-RenaultTwizy.pdf
That manual mentions (on page #29):
I suggest to check that. It is possible that, despite the early model year, the SEVCON controller in your Twizy has been previously upgraded to a later version.
Also see this table for SEVCON serial numbers: https://docs.google.com/spreadsheets/d/1rDZG5xdG1586_4EUU1bMjicZremXJFHSDVT0XqJNtJY/edit#gid=0
The model is from the year 2012 and in theory, it should not be blocked... I thought it was a problem with the OVMS V2 module. Is there any way to know if the switchboard is blocked so that I cannot delimit it? sending a CFG READS 1008 0? Many thanks
We have answered your question. Post your SEVCON readings according to the spreadsheet if you still think it should be tunable.
Ok. Many thanks
