After the last update to the OVMS app in Jan 2023, the app stopped working. I Uninstalled the app and tried to reconnect. But now get ovms server and password error. Anyone have an idea on how to resolve this issue?
And yes my passwords are correct. I've checked.
If you are getting a server/password error, the source of the problem should be that.
I suggest you check 'module summary' to see what is currentyl configured on the module. Then check:
If you can't get it working, and are using api.openvehicles.com, then raise a support ticket here with the output of 'module summary'.
Yes server is api.openvehicle.com and passwords are correct. Where do I post a support ticket?
I see a ticket from you, so you seem to have found it under 'Support' menu option.
But, please add output of 'module summary' to your ticket as we need that to check your confituration and start diagnosing your problem.
