13 posts / 0 new
stoatwblr
auxbatmon oddities
Anyone know what this indicates?
2023-01-21 15:29:41.686 GMT E (5222566) ovms-duktape: [lib/auxbatmon/auxbatmon.js:55] Error: alloc failed|    at [anon] (duk_hobject_props.c:1063) internal|    at push () native strict preventsyield|    at [anon] (lib/auxbatmon/auxbatmon.js:55) preventsyield|    at forEach () native strict preventsyield|    at ticker (lib/auxbatmon/auxbatmon.js:58)|    at callSubscriberWithImmediateExceptions (int/PubSub.js:1) strict|    at deliverMessage (int/PubSub.js:1) strict|    at c (int/PubSub.js:1) strict|    at publish (int/PubSub.js:1) strict|    at [anon] (int/PubSub.js:1) strict preventsyield
2023-01-21 15:30:41.686 GMT E (5282566) ovms-duktape: [lib/auxbatmon/auxbatmon.js:55] Error: alloc failed|    at [anon] (duk_hobject_props.c:1063) internal|    at push () native strict preventsyield|    at [anon] (lib/auxbatmon/auxbatmon.js:55) preventsyield|    at forEach () native strict preventsyield|    at ticker (lib/auxbatmon/auxbatmon.js:58)|    at callSubscriberWithImmediateExceptions (int/PubSub.js:1) strict|    at deliverMessage (int/PubSub.js:1) strict|    at c (int/PubSub.js:1) strict|    at publish (int/PubSub.js:1) strict|    at [anon] (int/PubSub.js:1) strict preventsyield
dexter
dexter's picture
auxbatmon oddities
"alloc failed" normally means the scripting framework ran out of memory.
If you configured a lower heap size as described here https://docs.openvehicles.com/en/latest/userguide/scripting.html#heap-memory you could try raising that. Use command "script meminfo" to see if that's the issue.
stoatwblr
I had a suspicion that might
I had a suspicion that might be the case. History was bumped to 168 hours (1 week) but heap wasn't touched (this was in order to better see discharge profiles)
stoatwblr
This is just after reboot and
This is just after reboot and attempting to load the 12V history web page (which failed)
OVMS# script meminfo
  "totalBytes": 524224,
  "usedBytes": 343520,
  "freeBytes": 180704,
  "largestFreeBytes": 99232,
  "memlib": "umm",
  "ummTotalEntries": 2232,
  "ummUsedEntries": 2191,
  "ummFreeEntries": 41,
  "ummTotalBlocks": 16382,
  "ummUsedBlocks": 10735,
  "ummFreeBlocks": 5647,
  "ummMaxFreeContiguousBlocks": 3101,
  "ummUsageMetric": 190,
  "ummFragmentationMetric": 42
interestingly the history page loaded a few minutes later, so the memory must be pretty close to the ragged edge of oblivion
here's what it's like with the 12V history page displaying
  "usedBytes": 353536,
  "freeBytes": 170688,
  "largestFreeBytes": 94272,
  "memlib": "umm",
  "ummTotalEntries": 2562,
  "ummUsedEntries": 2553,
  "ummFreeEntries": 9,
  "ummUsedBlocks": 11048,
  "ummFreeBlocks": 5334,
  "ummMaxFreeContiguousBlocks": 2946,
  "ummUsageMetric": 207,
  "ummFragmentationMetric": 34
stoatwblr
hmmm. After bumping to 768kB
hmmm. After bumping to 768kB and issuing a reload, I see this:
  "totalBytes": 786368,
  "usedBytes": 180256,
  "freeBytes": 606112,
  "largestFreeBytes": 593344,
  "memlib": "umm",
  "ummTotalEntries": 2325,
  "ummUsedEntries": 2266,
  "ummFreeEntries": 59,
  "ummTotalBlocks": 24574,
  "ummUsedBlocks": 5633,
  "ummFreeBlocks": 18941,
  "ummMaxFreeContiguousBlocks": 18542,
  "ummUsageMetric": 29,
W (568595) websocket: WebSocketHandler[0x3f8bcc6c]: job queue overflow detected
W (568605) websocket: WebSocketHandler[0x3f8bcc6c]: job queue overflow detected
W (568615) websocket: WebSocketHandler[0x3f8bcc6c]: job queue overflow detected
W (568635) websocket: WebSocketHandler[0x3f8bcc6c]: job queue overflow detected
W (568655) websocket: WebSocketHandler[0x3f8bcc6c]: job queue overflow detected
W (568695) websocket: WebSocketHandler[0x3f8bcc6c]: job queue overflow detected
W (568705) websocket: WebSocketHandler[0x3f8bcc6c]: job queue overflow detected
The job queue messages are utterly spamming everything else
The module rebooted itself about 2 minutes after this reload
stoatwblr
All seems stable after the
All seems stable after the reload, but the history file has been erased (no big deal, the voltage traces showed it was clearly in error and only being recorded intermittently )
For some reason the Trio configuration is not picking up or recording DCDC 12V charger current (which will make checking things more difficult when I refit to the car) and there's no direct measurement of actual 12V battery net input/output available without fitting more instrumentation to the car (a 12V CAN-conneccted coulombometer would be ideal, of course, but these run to about €300 apiece and wouldn't work when keyed-off unless there's some way of storing/flushing data when power returns)
stoatwblr
another day another fw
another day another fw upgrade
With 6.5 days worth of data in the log, 768kB turns out to be not enough and the dreaded alloc error message has returned after rebooting
What's interesting is the amount of free ram compared to the last time around
  "usedBytes": 451328,
  "freeBytes": 335040,
  "largestFreeBytes": 54752,
  "memlib": "umm",
  "ummTotalEntries": 2217,
  "ummUsedEntries": 2170,
  "ummFreeEntries": 47,
  "ummUsedBlocks": 14104,
  "ummFreeBlocks": 10470,
  "ummMaxFreeContiguousBlocks": 1711,
  "ummUsageMetric": 134,
  "ummFragmentationMetric": 65
E (542523) ovms-duktape: [lib/auxbatmon/auxbatmon.js:55] Error: alloc failed
……:     at [anon] (duk_hobject_props.c:1063) internal
……:     at push () native strict preventsyield
……:     at [anon] (lib/auxbatmon/auxbatmon.js:55) preventsyield
……:     at forEach () native strict preventsyield
……:     at ticker (lib/auxbatmon/auxbatmon.js:58)
……:     at callSubscriberWithImmediateExceptions (int/PubSub.js:1) strict
……:     at deliverMessage (int/PubSub.js:1) strict
……:     at c (int/PubSub.js:1) strict
……:     at publish (int/PubSub.js:1) strict
……:     at [anon] (int/PubSub.js:1) strict preventsyield
as with last time, increasing the memory and issuing a script reset resulted in a mountain of errors and the module needed rebooting
E (814333) uart_events: uart event type: 4
W (814483) websocket: WebSocketHandler[0x3f8f9f58]: job queue overflow detected
W (814493) websocket: WebSocketHandler[0x3f838398]: job queue overflow resolved, 78 drops
(hundreds of lines removed)
Having rebooted, the datafile was immediately readable - no data loss this time
  "totalBytes": 1048480,
  "usedBytes": 450080,
  "freeBytes": 598400,
  "largestFreeBytes": 437184,
  "memlib": "umm",
  "ummTotalEntries": 2292,
  "ummUsedEntries": 2215,
  "ummFreeEntries": 77,
  "ummTotalBlocks": 32765,
  "ummUsedBlocks": 14065,
  "ummFreeBlocks": 18700,
  "ummMaxFreeContiguousBlocks": 13662,
  "ummUsageMetric": 75,
  "ummFragmentationMetric": 25
stoatwblr
Hmm. looking closer at the
Hmm. looking closer at the logfile, I can see it DID stop recording data for an unknown period and judging from the external observation of the test rig voltmeter I think it's lost about 18 hours
I haven't looked closely at the code yet
Michael, does the logfile actually include timestamps or just data points?
dexter
dexter's picture
Just data points to save RAM.
Just data points to save RAM. As data points are taken at a defined interval, it only needs to know the time of the last point, which is history["time"].
Be aware the memory usage info is dynamic due to garbage collection. GC is done automatically once per minute *after* processing the events, and can also be done manually by "script compact".
168 hours x 60 minutes x 5 metrics = 50,400 number values. At 8 bytes per value (JS number), that's 403,200 bytes for the core value storage. For temporary buffers and array management, I'd assume about double that size is needed in RAM capacity, so I recommend setting the RAM to 1 MB or reducing the sample frequency or removing some of the tracked metrics.
stoatwblr
Which is fine, until it stops collecting for any reason..... (such as 12V low power sleep) - and then all the previous timestamps are incorrect as they're merely calculated backwards from "now" and a gap is in effect silently "bridged"
If the values are 8 bytes, then is it possible to encode multiple values into them to reduce memory consumption?
stoatwblr
it looks like 1Mb might not
it looks like 1Mb might not be enough
this popped up whilst debugging and testing after rewiring the GPS antenna power
E (184318) ovms-duktape: [lib/auxbatmon/auxbatmon.js:62] Error: alloc failed
……:     at [anon] (duk_hbuffer_ops.c:64) internal
……:     at encode () native strict preventsyield
……:     at ticker (lib/auxbatmon/auxbatmon.js:62)
W (184318) ovms-duktape: Duktape: event handling for 'ticker.60' took 2340 ms
dexter
dexter's picture
You can raise the memory or
You can raise the memory or rework the data storage. To reduce the memory footprint, I suggest evaluating typed arrays first:
These provide 32 bit floats. You may also be able to map readings to small integer elements by applying a fixed precisison. For example, the 12V reading multiplied by 10 will fit into a byte.
stoatwblr
I was thinking of something
I was thinking of something similar. There's definitely room for improvement. An 8 byte float is both overkill for the purpose and a big memory hit
