6 posts / 0 new
SPlatten
SPlatten's picture
What to get?
Can anyone help me, what bits do I need to purchase from:
https://shop.openenergymonitor.com/ovms/
In order to start exploring my Peugeot e-208 ?
I want to see if I can detect signal indicators, lights on / off, reverse, hazard indicators.
Thank you,
markwj
markwj's picture
From the OVMS point of view,
From the OVMS point of view, just a base wifi module. You can get modem + gps antenna + gsm antenna if you think useful in the future, but not necessary for initial investigation.
You will also need a vehicle specific cable, but that will depend on the vehicle CAN bus arrangement. Based on this post:
https://www.openvehicles.com/node/2505
pin 1 + 12v after power
pin 3 can high Peugeot
pin 4 body ground
pin 5 electro ground
pin 6 can high standard
pîn 8 can low Peugeot
pin 14 can low standard
pin 16 + 12v OBD
Although I haven't confirmed it myself, that seems to match one of Peugot's standard pinouts (https://pinoutguide.com/CarElectronics/peugeot_obd_ii_diag_pinout.shtml), and suggests you need pins 3+8 for Peugot CAN, and 6+14 for standard CAN. None of the standard OVMS cables have that arrangement. Probably the simplest is to get a standard OVMS cable (OB-L, or OB-R) cut it in two and re-arrange the wires in the centre yourself. Alternatively, get an OBDII pigtail and solder up the DB9 end yourself.
Happy hunting.
SPlatten
SPlatten's picture
Thank you Mark,  I have a
Thank you Mark,  I have a couple of ODBII cables I can cut and play around with.  Does the OVMS come with everything I need to investigage?
markwj
markwj's picture
Yes, the base OVMS (and firmware) includes tools to connect to up to 3 can buses, log traffic, inject traffic, and do reverse engineering.
SPlatten
SPlatten's picture
Thank you, when I get some
Thank you, when I get some funds I will purchase.
Hutje
Hi,
Hi,
Would you be willing to share any discoveries you make?
I really hope someone is able to add the e208 to the compatible cars on the GitHub.
The Car Scanner-app is compatible with the e208. Maybe someone with more experience is able to also implement it for OVMS.
https://www.openvehicles.com/comment/8608#comment-8608
