3 posts / 0 new
OscarCK
/store and /sd default structure/contents?
Can someone point me to the files and folders that should be in /store and /sd when the OVMS firmware has just been installed? Just wanna check that everything was installed correctly.
Oscar
markwj
markwj's picture
Should be just:
Should be just:
  • /store/ovms_config
SD would be whatever you had on there before
OscarCK
Ok, I thought it would have
Ok, I thought it would have made all the "plugin", "script" etc. folders that are montioned in the docs, and also the "backup" folder in the SD card since it is needed for the backup to even start.
Oscar
