3 posts / 0 new
smetana.przemys...
No battery temperature reading after battery replacement
Hi. I changed the battery in my leaf from 24 to 40 kWh. After finishing the work, I noticed that OVMS stopped seeing the battery temperature. LeafSpy sees the temperature correctly. Can you help fix this?
cods4
I have the same issue on my ZE1 40kWh
I have OVMS running on my ZE1 and I also don't get the battery temperature coming through. Hopefully if someone can help sort this out for you, I can benefit too.
LindseyP
Sorry, no help on the batt
Sorry, no help on the batt temp issue, but.... a quick run-down on your 24 to 40 upgrade would be wonderful! (I have a 2014 with a 24kwh battery). Where did you fine a 40 and which conversion tech did you use?
