3 posts / 0 new
jproveta
jproveta's picture
Start Charge
Hi,
I have a Smart ED/EQ 4.Gen, is there any way for to start charging the car using "http request" or another way? how ? I can do it in the app, but I wanted to create an automation in Home Assistant.
Thanks, smiley
JProveta
dexter
dexter's picture
Start Charge / Remote Command Execution
The command API info was scattered, I've just added a dedicated section to the manual:
Don't ask me how to do anything in Home Assistant though. But I'm sure there are lots of available templates & examples you can adapt.
toddq
If you're integrating with
If you're integrating with Home Assistant, I'd highly recommend using mqtt and the v3 server.  I used this project as a template to get started (thank you jdanders!) and it's been great.  You can see there's both a switch (toggle charging) and a button (start charging) in this config.
