2 posts / 0 new
spilegi
Brand New Vehicle Module not generating configuration Hotspot
Just got my Vehicle Module.
I plugged it in, but it doesn't appear to be generating the hotspot for initial configuration.
I work in IT so I plugged it into my computer and I do see it the module showing up as /dev/ttyUSB0.  I used this connection to attempt to Factory Reset the Module using esptool without success.  I also used the MicroSD card with a blank file factoryreset.txt which also didn't work.
I've plugged this into my cars OBD port as well as my PC and a 2a USB charger.  I'm used to working with ESP32's in Home Assistant, so I also flashed the latest firmware directly onto the module.  None of this has worked.
Has anybody come across this?  I don't have the serial cable needed for debugging, and I wanted to see if anyone had any ideas before I get one.
thanks!
markwj
markwj's picture
Debugging / console is via
Debugging / console is via the USB cable. No special serial cable needed. Just plug it in via USB and you should see the device show up as a comm port. Try 115,200 baud.
See here for details: https://docs.openvehicles.com/en/latest/userguide/console.html#console-connections
