Hi
Which leaf modelyear should I use for my E-NV200 (40kWh)?
I solved the issue. I'm not sure exactly what, but this is what I did:
(Not working means I tapped on "AC ON" in the app and heard some clicking sounds in the car, but it didn't start the climate control)
It didn't work out of the box. I enabled CAN bus write and set the model year to 2018 through the web ui. Still didn't work.
Then I set it to 2014 through the web ui, still didn't work.
Then I set the model year to 2018 through the console, and after that it started working.
I also enabled the ABRP integration around the same time (including reboots), so it might be related.
