I have been using OVMSv1 for many years without issues. Now I cannot get it to work anymore for many months.Not sure if something on the server side changed or if the module is actually broken. Any ideas howto debug this?
Thanks
Dominik
Thanks
Dominik
Ok, I'm answering my own question. The IP of www.openvehicles.com seemed to have changed. Now I'm wondering if I should better use ovms.dexters-web.de as I'm located in Germany? But this requires reregistering there, I guess.
If you use DNS (8.8.8.8) then you can simply use api.openvehicles.com and that will avoid having to use IP address.
