Hey folks!
I need your help on a special problem:
Everything went fine for nearly one year but - After beeing five days on vacation my Smart ED3 did not open by radio-key. 12V-Battery was now a 3V battery, hv-battery was down to 10%. Did a jump-start and charged normally on my wallbox.
The OVMS was completely resettet (by itself?!?) and i had to set it up again. Now, after replacing the damaged 12v-battery again all config is gone. even a simple reboot via web-interface crashes all config, module is booting with factory defaults...
Whats happening?
THX a lot for your support!
If a crash or power outage occurs just while writing data to the storage partition, it can become corrupted.
In that case do a manual factory reset (as forester did), then simply restore your most recent backup.
The restore can be done via USB console or web UI -- you don't need to walk through the setup wizard before.
