hi!
i'm new to ovms, i have a problem with the data usage exeeding the 25 mb/month ... i investigate a little (very little to be honest!) and i think it is related to the charging process ... i'm wrong?
i set the charging speed to 1Kw/h
here the last 3 days from ovm-utilization
2022-06-07 02:00:00,0,115364
2022-06-07 02:00:00,1,741548
2022-06-07 02:00:00,2,29724
2022-06-07 02:00:00,3,739690
2022-06-08 02:00:00,0,80706
2022-06-08 02:00:00,1,524248
2022-06-08 02:00:00,2,0
2022-06-08 02:00:00,3,522430
2022-06-09 02:00:00,0,96120
2022-06-09 02:00:00,1,605894
2022-06-09 02:00:00,2,5146
2022-06-09 02:00:00,3,605618
today i investigate a little more, i 've a lot of entry in the log file
rt-bat-p
rt-bat-c
even when the twizy is parked ....
if i understund this file report the BMS stats, but when the car isn't on and it isn't in charge the BMS is working?? why? we have always can data?
The Twizy tops up the 12V battery every ~35 minutes for about 5 minutes, that's when the BMS is active while parking.
Reducing data volume can be done by reducing intervals and suppressing certain types.
Read here:
