6 posts / 0 new
KYLE PAGE
Heater and A/C will not turn on from the app
Hi,Everyone Im new to OVMS
I put my module in a 2016 nissan leaf
the heater and a/c wont turn on from the app. it say it fails
I tryed to unplug the TCU module with no help, but now i have lost live data on the TPMS.
Anyone have any ideas what to try next?
Kyle
fonzeka
Did you enable CAN writes?
You can find the option under features in the web console.
KYLE PAGE
I just enabled CAN
I just enabled CAN
Now it works
Should i set the the year to 2015 instead of 2016?
Thank you so much
I will try putting the TCU back in and see if it still works and i get back my TPMS.
Kyle
KYLE PAGE
I put the TCU back in.
No heater A/C or TPMS.
i unpluged the TCU heater a/c works.
I don't know what i did to stop the TPMS from showing in the app?
that's a small price to pay for heater and a/c working now.
You are all the best, keep up the good work you are doing for open source......
Kyle
cquarinto
You may be able to get the
You may be able to get the TPMS readings after you drive the car for a couple of Kms. - I have a 2015 with navigation so I had to unplug the TCU - Be aware that the TCU has other connectors .. and the instructions only indicated to remove the main connector. - Hope this helps! :)  - And you are right - this thing Rocks!
KYLE PAGE
All is good now!!!!!!
Heater A/C working fine. Door lock and unlock work great.
TPMS is now working from the app.
JUST a FYI I mounted the OVMS  module under the glove box plastic cover. very easy to get too.
Also purchaseted two OBD II spliter cables and ran the cable to the others side fo the car for a very clean install.
 You gyus rock, thanks for everones help
