3 posts / 0 new
Lothsahn
Crash report for vehicle module
Mark and all,
Thanks so much for all your work on OVMS.  It's allowing me to limit the maximum battery charge on my Leaf and save my battery.  I'm quite happy with it.
That said, I have a crash in the vehicle module history, and thought you might want it.  It's possible it was due to an electrical disconnect or something else--my vehicle was at the mechanic's when this happened.  Wanted you to have it, in case it would help!
Last boot was 1423983 second(s) ago Time at boot: 2024-08-12 09:54:58 CDT This is reset #3 since last power cycle Detected boot reason: Crash (12/12) Reset reason: Exception/panic (4) Crash counters: 3 total, 0 early Last crash: LoadProhibited exception on core 1 Registers: PC : 0x401328fd PS : 0x00060530 A0 : 0x80167f2c A1 : 0x3ffc87f0 A2 : 0x3f8b7bd0 A3 : 0x3f8b7b44 A4 : 0x000000b2 A5 : 0x0000ff00 A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x05706374 A9 : 0xbaad5678 A10 : 0x66ba2232 A11 : 0x41d9ae88 A12 : 0x0000001f A13 : 0x66ba2232 A14 : 0x7ff00000 A15 : 0x7ff9ae88 SAR : 0x00000001 EXCCAUSE: 0x0000001c EXCVADDR: 0x0570637c LBEG : 0x400029ac LEND : 0x400029cb LCOUNT : 0x00000000 Current task on core 0: IDLE0, 524 stack bytes free Current task on core 1: OVMS Events, 3932 stack bytes free Backtrace: 0x401328fd 0x40167f29 0x40169f09 0x4016c44a 0x40167a0e 0x4011f1da 0x4011f3a9 0x4011f490 0x4011f519 Event: ticker.1@ovms-server-v2 0 secs Version: 3.3.004-4-gab8f16b7/ota_0/main (build idf v3.3.4-849-g6e214dc335 Mar 30 2024 08:08:21) Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3
Lothsahn
Another crash
My vehicle module stopped communicating with the server.  The app said it hadn't checked in 12 hours, so I went to look at its status page and the website for the vehicle module would not load.
My router said its IP address was allocated to Expressif Inc.
I power cycled the unit and it came right up.  Checked in with my server and the vehicle module website is working as expected.
I have automatic power management disabled, the 12v shutdown voltage is 11.5, the wakeup voltage is 11.9, and my 12v battery is reading 13v.  I calibrated the battery, so I don't think it was a low voltage shutdown.
Any ideas?
Lothsahn
Device just crashed again.
Device just crashed again.  Although I have the charge limit set to 69%, the car charged to 100% overnight.  Checking on the module it wasn't checking into the server and the vehicle module webpage wasn't responding.
