1 post / 0 new
nile
start/stop climate control via webinterface (plugin)?
I've got my OVMSv3 module yesterday and it is working fine. I have connected to OBD2-Port, configured ovms-Server and Android app and everything is working fine (incl. accessing climate control via app).
Next time I will test if it is possible to move connection to now free old TCO plug, which contains two can buses (one of them is ev-can and I hope the other is main can as on OBD2 connector) - but this is a different story and I will report if it is working. If so I can design a small adapter pcb which contains connector for TCU plug, electronics to get handsfree mic working and 9p D-Sub cable so that OVMS module is plug and play at TCU connector..
But now question: Is there any plugin to access climate control via browser (web interface) of OVMS module? Or how can I set climate control on/off and read status via command (shell)? It would be a very small work to add buttons for climate control and read climate status to web interface via plugin...
Best regards
nile
