1 post / 0 new
wrn
Reprogram Sevcon from other Twizy
Greetings!
I have replaced a broken Sevcon in my Twizy with a used one. I need to reprogram it.
The version is not locked.
OVMS# xrt cfg read 100a 00
Read 0x100a.00: dec=858797872 hex=0x33303730 str='0703.0017'
Errors I get in the log:
E (1881420) v-twizy: Twizy type unknown: SEVCON type 0x0701302d"
And:
RT-ENG-LogAlerts,0,86400,5441,|Return to Base|Incompatible hardware version|Detected controller hardware version incompatible with software|Check correct software is programmed into controller. Reprogram if necessary
RT-ENG-LogAlerts,1,86400,4682,|Warning|IO can't init|Controller has not received all configured RPDOs at power up|Check PDOs on all CANbus nodes are configured correctly and match up.
Is it possible to use OVMS' CAN capabilities to reprogram the unit?
