2 posts / 0 new
alwindsor
Cellular Connection Stopped Working
I've happily been using an OVMS in my 2016 Leaf for almost a year and a half now. It's been great. But a few days ago it stopped connecting to the cellular network. All other functionality is still fine. It works as it should when it connects to my wifi. It still limits charging to my selected 'Sufficient SOC' when away from wifi too. It's just that I can't connect to it through my phone app when it's away from my home wifi. I have a Hologram SIM, with credit on the account. It has otherwise been nearly flawless since I installed it. I'm looking for some help diagnosing the problem.
Here's the module summary:
OVMS MODULE SUMMARY
Module
  Version: 3.3.003/ota_1/main (build idf v3.3.4-848-g1ff5e24b1 Sep 1 2022 08:40:30)
  Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
  12v: 11.9v
MODEM Status
  Model: SIM7600
  Network Registration: Searching
    Provider:
    Signal: -51 dBm
    Mode:
  State: NetWait
    Ticker: 2859
    User Data: 0
  UART:
    FIFO overflows: 0
    Buffer overflows: 0
    Parity errors: 0
    Frame errors: 0
    Driver Buffer overflows: 0
  Mux: Status up
    Open Channels: 4
    Framing Errors: 0
    RX frames: 5288
    TX frames: 295
    Last RX frame: 2 sec(s) ago
  PPP: Not running
  GPS: Connected on channel: #1
     Status: enabled
     Time: enabled
Configuration
  [auto]
    dbc: no
    egpio: no
    ext12v: no
    init: yes
    modem: yes
    obd2ecu:
    scripting: yes
    server.v2: yes
    server.v3: no
    vehicle.type: NL
    wifi.mode: apclient
    wifi.ssid.ap: LEC205
    wifi.ssid.client: Shish Kabob
  [can]
  [dbc]
  [egpio]
    monitor.ports:
  [http.plugin]
  [http.server]
  [locations]
  [log]
  [modem]
    apn: hologram
    apn.password:
    apn.user:
    enable.gps: yes
    enable.gpstime: yes
    enable.net: yes
    enable.sms: yes
    pincode:
  [module]
    cfgversion: 2020053100
    init: done
  [network]
    dns:
  [notify]
  [obd2ecu]
  [obd2ecu.map]
  [ota]
    http.mru: https://api.openvehicles.com/firmware/ota/v3.3/main/ovms3.bin
    server: https://api.openvehicles.com/firmware/ota
  [password]
    module: **redacted**
    server.v2: **redacted**
  [plugin]
  [plugin.disabled]
  [plugin.enabled]
  [plugin.repos]
  [power]
  [pushover]
  [sdcard]
  [server.v2]
    server: api.openvehicles.com
    tls: yes
  [server.v3]
  [ssh.info]
    fingerprint: lxahRgeXFk9wMc7m/s3jThGNnAUOezjzvVPfQE+qnTs
  [ssh.keys]
  [ssh.server]
    key: **redacted**
  [system.adc]
    factor12v: 195.7
  [tpms]
  [usr]
  [vehicle]
    12v.alert:
    12v.ref:
    name:
    stream: 1
    timezone:
    timezone_region: -Custom-
    units.distance: K
  [wifi.ap]
    LEC205: **redacted**
  [wifi.ssid]
    Shish Kabob: **redacted**
  [xnl]
    autocharge: yes
    cabintempoffset: .0
    canwrite: yes
    cfg_ev_request_port: 1
    maxGids: 502
    minrange: 0
    minsoc: 0
    modelyear: 2016
    newCarAh: 115
    rangedrop: 0
    soc.newcar: no
    socdrop: 0
    soh.newcar: yes
    suffrange: 0
    suffrangecalc: ideal
    suffsoc: 80
REPORT ENDS
I thought it was weird that it would suddenly stop, so I gave it a few days. It's now been a week. I did try putting a working SIM from a phone into it, and the module summary read as:
OVMS MODULE SUMMARY
Module
  12v: 14.6v
MODEM Status
  Model: SIM7600
  Network Registration: RegisteredHome
    Provider: Koodo
    Signal: -79 dBm
    Mode: WCDMA;Online
  State: NetLoss
    Ticker: 8
    User Data: 0
  UART:
    FIFO overflows: 0
    Buffer overflows: 0
    Parity errors: 0
    Frame errors: 0
    State Timeout Goto: NetWait (in 2 seconds)
  Mux: Status up
    Open Channels: 4
    Framing Errors: 0
    RX frames: 105
    TX frames: 40
    Last RX frame: 9 sec(s) ago
  PPP: Not connected
     Last Error: User Interrupt
     Status: enabled
     Time: enabled
… the remainder of the status report is identical to the first one.
REPORT ENDS
It shows the right cellular provider but it still doesn’t work. I couldn't connect to the module once it was away from wifi. I'm assuming because I didn't update any APN settings in the module.
Does this indicate the OVMS hardware is okay but the Hologram SIM isn't connecting to the cellular network? Is there a way to test the SIM?
Any advice is appreciated. Thank you.
markwj
markwj's picture
Correct
Yes. Are you sure you have balance on your account for the hologram SIM? Also note that there has been a lot of 2G and 3G shutdowns recently and we have heard some very old Hologram SIMs don't support 4G.
