1 post / 0 new
eustache38100
My Nissan Leaf 2 installation experience
Hello everyone,
I just installed an OVMS box on a 2018 Nissan Leaf ZE1 and wanted to share my experience.
Thanks for the support—it was very useful! There are three main steps:
  1. Cable making
  2. Cable installation
  3. OVMS box configuration
I recommend doing these three things on different days.
  1. Cable Making
I used this official document to make the custom cable, with some adaptations for a DB9 connector:
https://docs.openvehicles.com/en/latest/_downloads/1646e468de2bd4b3b5114c214970f277/Leaf-ZE1-CAN-Tap-Wiring.pdf
I bought variants slightly different from the initial cable proposal:
Here is my wiring scheme using the two cables above:
Don’t forget to check your soldering!
  1. Cable Installation
You need access behind the instrument cluster and the glove box. Here are two helpful videos:
CAN bus cable installation:
TCU Installation:
After removing the glove box, you need to unscrew the three circled screws to access the TCU.
I recommend cutting the wires. Why? If the community finds a solution to clear error messages, it will be with the box connected in-line between the cut wires. Furthermore, removing individual pins is difficult and you can easily break the connector!
I couldn't find a pre-assembled 40-pin cable (unlike the 24-pin extension cable) to cut the wires into the extension.
If anyone knows the connector's name or can find a site selling an extension cable, please share it!
Where to place the OVMS box?
I decided to place it inside the glove box. You don't need to dismantle the entire dashboard; the cable installation is quite easy.
  1. OVMS Box Configuration
Before connecting the box or doing the Hologram activation, create an account at https://dexters-web.de. Add your car configuration and keep your login details for later.
I recommend doing the configuration before connecting the OVMS box in the car.
First connect the GPS and GSM antennas, and plug in the micro-USB cable (use a standard phone charger; stable voltage is important).
Once the OVMS box is powered ON, connect your laptop to the OVMS Wi-Fi:
  • Wi-Fi SSID: OVMS
  • Password: OVMSinit
Open your web browser and go to: http://192.168.4.1/
Follow the setup wizard, add your home Wi-Fi, etc.
Once your configuration is done, connect the OVMS box to your car and check that it's working. You can now do your GSM/Hologram activation.
I hope it will help.
