2 posts / 0 new
wsanders
How to get PIDs from the Github source?
I am trying to get some PIDs for my 2023 Niro EV and it seems like the OVMS source tree on Github (https://github.com/openvehicles ?) ought to have the definitions somewhere. Can someone help me with a brief pointer to where the PIDs are enumerated? The "E-Niro" and Kona EV seem to be supported.
My objective is not to go full-on with OVMS, I'm just looking for a few of PIDs like max and min cell voltage and output KW. I have a ScanGauge II, and I;d like to keep it since it's small and unobtrusive. If I have a PID I should be able to work out the "Xgauge" settings so the ScanGauge can report the data. ScanGauge support says they do not support EVs. I think the ScanGauge is connecting to the vehicle, because I get a battery voltage readout, but I don't know whether the ScanGauge is getting it from the PID or just reading the voltage on the OBD connector.
markwj
markwj's picture
You can look in the vehicle
You can look in the vehicle support files for that type:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/tree/master/vehicle/OVMS.V3/components/vehicle_kianiroev
