I am trying to get some PIDs for my 2023 Niro EV and it seems like the OVMS source tree on Github (https://github.com/openvehicles ?) ought to have the definitions somewhere. Can someone help me with a brief pointer to where the PIDs are enumerated? The "E-Niro" and Kona EV seem to be supported.
My objective is not to go full-on with OVMS, I'm just looking for a few of PIDs like max and min cell voltage and output KW. I have a ScanGauge II, and I;d like to keep it since it's small and unobtrusive. If I have a PID I should be able to work out the "Xgauge" settings so the ScanGauge can report the data. ScanGauge support says they do not support EVs. I think the ScanGauge is connecting to the vehicle, because I get a battery voltage readout, but I don't know whether the ScanGauge is getting it from the PID or just reading the voltage on the OBD connector.
You can look in the vehicle support files for that type:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/tree/master/vehicle/OVMS.V3/components/vehicle_kianiroev
