4 posts / 0 new
Paul Wolstenholme
Latest official firmware
My OVMS is running firmware
3.3.003/ota_1/main (build idf v3.3.4-848-g1ff5e24b1 Sep 1 2022 08:40:30)
with automatic updates from the default site
https://api.openvehicles.com/firmware/ota
with the update tag not specified so that it defaults to main.
The help system says there should be 1 - 2 updates per year - so is there something wrong with the release process?  See:
https://docs.openvehicles.com/en/latest/userguide/ota.html#ota-build-versions
I want to start looking into why some things haven't been working for me and reporting some bugs, but I'm not sure how wise that is while the official version I'm finding fault in is nearly 4 years and a number of versions old.
I've followed the instructions.  Is this the firmware I should be using?
Thanks.
markwj
markwj's picture
I think historically the
I think historically the <main> tag is updated once every year or two (more in the early days, but recently things have stabilised much more). The <eap> tag is updated about twice as often as that (usually one or two updates leading up to the <main> release). The <edge> tag is updated nightly.
There is a new <main> release coming soon (already released on Dexter's and about to be released on API). That is already in <eap> on API (3.3.006-172-g362f8742).
P.S. As always note that <edge> is for developers and technical users only. Be aware that there may be bugs in those nightly builds.
Paul Wolstenholme
Firmware update released
Thanks to those who have issued the first main update in 3 years and 11 months!
Last boot was 26593 second(s) ago
Time at boot: 2026-08-04 02:12:14 NZST
This is reset #0 since last power cycle
Detected boot reason: PowerOn (12/12)
Reset reason: Unknown/unset (0)
Firmware: 3.3.006-172-g362f8742/ota_0/main (build idf v3.3.4-854-g9063c8662 Aug 3 2026 05:00:02, product v3.3)
The above (from the OVMS status web page) is mostly true.  I know the reset reason was the automatic firmware update and that there was NO power interruption.
I'm now in a better position to delve into the problems I've been having - if they are still there.
markwj
markwj's picture
Just to re-iterate:
Just to re-iterate:
  • MAIN updated once or twice a year, most stable and tested
  • EAP (early access program) updated usually a few times before each MAIN release, something like a Release Candidate
  • EDGE bleeding edge nightly builds
