4 posts / 0 new
trig
Twizy45 - CFG PRE: ERROR
Hi,
I have a Twizy 45
I installed the ovms module successfully and the android app works good !
I use the last firmware: 2.6.6
I have a problem when i try to enter in CFG PRE mode.
The module returns the following error :
CFG PRE : ERROR 0020 SDO 0x5110.00: 0x0005
Here is my config :
MODULE?
Module:
VehicleID:TWIZY45TRIG
VehicleType:RT
Units:K
Notifications:SMSIP
SERVER?
Server:
IP:64.111.70.40
Password:**********
Paranoid:-
GPRS?
GPRS:
APN:Free
User:
Password:
GSM:Orange
GPRS: OK
Server: Connected OK
STAT
Not charging
Full charge: 20 min.
Range: 61 - 61 km
SOC: 96.94% (76.78%..98.76%)
ODO: 10520 km
DIAG
DIAG:
RED Led:0
GRN Led:1
Net State:0x0020
12V Line:13.8 ref=0.0
Crashes:2
..last: TO - 54
Thanks in advance for your precious help
Cordially,
TRiG
trig
Found the solution.
Found the solution.
In order to use CFG mode, the twizy must not be on GO mode, only turned on.
EdLaPoignee
Firmware Download Link?
Hi,
can you give me a download link for the 2.6.6 RT firmware? I can't find it.
jose jimenez
twizy
donde puedo encontrar firmware 2.6.6 rt para un twizy 45
