Hi,
I have a Twizy 45
I installed the ovms module successfully and the android app works good !
I use the last firmware: 2.6.6
I have a problem when i try to enter in CFG PRE mode.
The module returns the following error :
CFG PRE : ERROR 0020 SDO 0x5110.00: 0x0005
Here is my config :
MODULE?
Module:
VehicleID:TWIZY45TRIG
VehicleType:RT
Units:K
Notifications:SMSIP
SERVER?
Server:
IP:64.111.70.40
Password:**********
Paranoid:-
GPRS?
GPRS:
APN:Free
User:
Password:
GSM:Orange
GPRS: OK
Server: Connected OK
STAT
Not charging
Full charge: 20 min.
Range: 61 - 61 km
SOC: 96.94% (76.78%..98.76%)
ODO: 10520 km
DIAG
DIAG:
RED Led:0
GRN Led:1
Net State:0x0020
12V Line:13.8 ref=0.0
Crashes:2
..last: TO - 54
Thanks in advance for your precious help
Cordially,
TRiG
Found the solution.
In order to use CFG mode, the twizy must not be on GO mode, only turned on.
Hi,
can you give me a download link for the 2.6.6 RT firmware? I can't find it.
donde puedo encontrar firmware 2.6.6 rt para un twizy 45
