Notifications ceased to come after updating to the latest version. Nissan Leaf 2015 model year. I tried to reinstall the application - there is no result. ovms.dexters-web.de server. also lost the ability to enter GCM sender ID: 1043773844049. ps installed the application version 3.13.2 - notifications regularly come.
Janik,
push notifications generally work just as before, in all versions.
There also has been no change to the App code with regard to notifications.
You also didn't lose the ability to enter a custom GCM sender ID, the server selector removes the need to do so if using a standard server. If you're using your own server, set it to custom.
Maybe your previous APK was signed differently and you need to allow notifications in the Android settings again after installing the new version?
Michael, I don’t receive notifications in this application window:
at the same time I get email notifications:
etc...
allow notifications in the Android - this is also okay.
thanks!
Did you activate the new message filter feature?
And if so, do you possibly have a caps mismatch in your vehicle ID?
Did you activate the new message filter feature? - if I send the "stat" command I get a response from the machine. can you tell me how I can check the message filter?
And if so, do you possibly have a caps mismatch in your vehicle ID? - all is well with it!
thanks!
Is your Vehicle ID uppercase? Like MYCARID or Mycarid?
I registered the car on the site dexters-web.de with the name "MyCar"(example), the application specifies exactly the same name, observing the case of letters.
thanks.
