7 posts / 0 new
Janik
Janik's picture
Android notifications not coming
Notifications ceased to come after updating to the latest version. Nissan Leaf 2015 model year. I tried to reinstall the application - there is no result. ovms.dexters-web.de server. also lost the ability to enter GCM sender ID: 1043773844049. ps installed the application version 3.13.2 - notifications regularly come.
dexter
dexter's picture
Janik,
push notifications generally work just as before, in all versions.
There also has been no change to the App code with regard to notifications.
You also didn't lose the ability to enter a custom GCM sender ID, the server selector removes the need to do so if using a standard server. If you're using your own server, set it to custom.
Maybe your previous APK was signed differently and you need to allow notifications in the Android settings again after installing the new version?
Janik
Janik's picture
Michael, I don’t receive
Michael, I don’t receive notifications in this application window:
at the same time I get email notifications:
Vehicle is idling / stopped turned on
- Charging
391.5V/0.5A
SOC: 96.0%
Ideal range: 103km
Est. range: 75km
ODO: 46884.9km
CAC: 50.1Ah
SOH: 80%
etc...
allow notifications in the Android - this is also okay.
thanks!
dexter
dexter's picture
Did you activate the new message filter feature?
And if so, do you possibly have a caps mismatch in your vehicle ID?
Janik
Janik's picture
Did you activate the new message filter feature? -  if I send the "stat" command I get a response from the machine. can you tell me how I can check the message filter?
And if so, do you possibly have a caps mismatch in your vehicle ID? - all is well with it!
thanks!
Dimitrie
Is your Vehicle ID uppercase?
Is your Vehicle ID uppercase? Like MYCARID or Mycarid?
Janik
Janik's picture
I registered the car on the
I registered the car on the site dexters-web.de with the name "MyCar"(example), the application specifies exactly the same name, observing the case of letters.
thanks.
