13 posts / 0 new
movtarget
4G Hologram sim connecting to USCellular, but no data transmission
Two days ago I installed OVMS in a 2017 Leaf. Usage over wifi (both AP and client) works as expected, but I'm having trouble with Hologram SIM data throughput. The Hologram site shows "connected" (blue), but not "live" (green) with 0 data throughput. Cellular and GPS antennas attached.
Only side-note is that I have NOT disconnected TCU yet. I would think this wouldn't impact the cellular link from OVMS module, but I'm a newbie.
On the OVMS web status, I get this from the cellular modem panel:
MODEM Status Model: SIM7600
Network Registration: DeniedRegistration
Provider: USCellular Hologram
Signal: -77 dBm
Mode:
State: NetWait
Mux: Status up
PPP: Not running
GPS: Connected on channel: #1
Stanton
Stanton's picture
If you're not getting any
If you're not getting any data transmitted, then something is wrong with your modem config; you shouldn't get a "DeniedRegistration" message.
I recommend removing the module from your car (along with the wireless antenna) and try connecting "stand-alone". That way you can check/modify the modem config verify the cellular signal (although -77 dBm should be sufficient).
Stanton
Stanton's picture
Don't forget to download the correct (v3.3) firmware
from the "edge" area
movtarget
Yes, I’m on edge 3.3 2/20/2022
Thanks, I've loaded the edge 3.3 from 2/20/2022
movtarget
Update: 100% SIM/Hologram related
Put the SIM in an unlocked “all carriers” Moto android phone. Sees T-Mobile, Hologram site shows “connected”, no data. I need to work this as a hologram problem. Could also be weak signal and initial registration falters (-77 to -85 dBm), but not as likely
movtarget
Started workin coming home from work
it Found AT&T instead of USCellular, now working. I did not get to the level of AT commands to force find alternate carriers, but it appears to have done that on its own (recall that I put the SIM in an android phone that saw T-mobile). I will follow up in this same thread with updates.
2448374
Update?
Any follow up here?  My problems are very similar and intermittent.  Still having trouble or is it fixed now?
movtarget
Still not working most of the time
Only worked twice. I have since tried a series of AT commands without any evidence they are getting through. That could just be syntax. My plan is to dig a little deeper week after next (currently traveling/working)
nismoman240sx
Subbing for a solution to
Subbing for a solution to this as well. Exact same problems. New install on 4/1.
path2insanity
Nothing for April for some reason.
March 28th was the last time I was able to get any connection hologram.
Only Wifi is working. Solar Flare maybe?
Is there a way to force it to transmit while at home (while hooked up to wifi)?
path2insanity
Figured
It was a solar flare;
https://blogs.nasa.gov/solarcycle25/2022/03/30/significant-solar-flare-erupts-from-sun-2/#:~:text=Solar%20flares%20are%20powerful%20bursts,as%20an%20X%2DClass%20flare.
Everything works normal now.
nismoman240sx
Mine seemed to sort itself
Mine seemed to sort itself out. I think for me it was an antenna placement issue. Once I moved it, it connected and has been working fine ever since.
path2insanity
Whats your signal strength?
Network Registration: RegisteredRoaming
Provider: AT&T Hologram
Signal: -51 dBm
Mode: LTE, Online
State: NetMode
Mux: Status up
PPP: Connected channel #2
GPS: Connected channel #1
