no, but i have made a test Firmware with some changes. Can you test it pls?
go to Firmware: Flash from Web. Http URL: ovms.dimitrie.eu/firmware/ota/v3.1/main/ovms3.bin
You get two of 96 pairs of data. If you combine four hex numbers and convert it into binary you will get a number that is very similat to a voltage readings:
Hi,
did you enable can Write under features?
Yes, I did.
Then i need more info,
can you please type into Shell when Ignition is on:
obd can1 req dev 79B 7BB 2141
obd can1 req dev 79B 7BB 2142
config list xsq
and post the output
I (62172779) webcommand: HttpCommandStream[0x3f8b2044]: 3517800 bytes free, executing: config list xsq
and please,
me li volt
other looks ok
OVMS# me li volt
v.b.12v.voltage 12.3V
v.b.12v.voltage.alert
v.b.12v.voltage.ref 12.6V
v.b.c.voltage
v.b.c.voltage.alert
v.b.c.voltage.dev.max
v.b.c.voltage.max
v.b.c.voltage.min
v.b.p.voltage.avg
v.b.p.voltage.grad
v.b.p.voltage.max
v.b.p.voltage.min
v.b.p.voltage.stddev
v.b.p.voltage.stddev.max 0V
v.b.voltage 377.5V
v.c.12v.voltage
v.c.voltage
v.g.voltage
Any thoughts why nothing shows up on "BMS cell monitor"?
let me know if it works
Unfortunately keeps not showing anything...
can you send me the shell log output when you you set the log level to verbose.
in shell type: log level verbose
then make ignition on
OVMS# log level verbose
Logging level for * set to verbose
D (4061054) pushover: EventListener: Handling event (clock.1850)
D (4061054) pushover: EventListener: No priority set -> ignore notification
D (4082054) pushover: EventListener: Handling event (ticker.60)
D (4082054) pushover: EventListener: No priority set -> ignore notification
V (4082064) ovms-duktape: Duktape: Compacting DukTape memory
D (4082124) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms
pls test my Firmware again version: 3.3.001-281-g6dfd313f-dirty
Still no joy...![sad sad](https://www.openvehicles.com/sites/all/libraries/ckeditor/plugins/smiley/images/sad_smile.png)
Now I get all blank again
Today I got readings, bu not sure how to interpret.
Cell avg3.828V
Cell min3.781V
Cell max3.852V
StdDev22.8mV
StdDev max4.6mV
Gradient-68.9mV
Cell avg0.0°C
Cell min0.0°C
Cell max0.0°C
StdDev0.0°C
StdDev max0.0°C
I also have a ForTwo EQ and want to read individual cell voltages etc. Did you have any luck to get so far ?
I get data as I said, but can't interpret it. It seems there's one cell that deviates.
